C30 front suspension components on a c10
shortduallyC10
Vancouver, WA
Jeramy
350 ci
Hello All, well I'm finally hoping back onto my c10 to c30 project and need some help. The truck currently has all c10 suspension on it but I will be turning into a legit dually. Right now the rear is running a 5 lug custom dually hub kit wich works but is not legit in my opinion but has been on there since my dad bought the truck when I was a 6th grader. The front is all c10 5x5 lug set up but I would like to install c30 dually style hub and brakes along with drop spindles. Can I just use hubs, spindles, and new c30 brake calipers for the front or do I need to install new c30 control arms as well? Any info would be greatly appreciated. I know ill need a dually rear wich my friend will install for me.
Tank6x2
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Bucket and blues are more knowledgeable on this one for sure, didn’t realize how many differences there are with the a frames
The C10 has different control arms and bushings, compared to the 20/30 trucks. Iirc, the ball joints are smaller as well.
bluex
Spartanburg SC
C15
Correct
The way to do this is to change everything from the a-arms out. If its just for looks (which it would be) then you can keep the C10 spring for a better ride.
It might look like a C30 but it'll always be a C10. There are big differences in the frames, so please don't do this thinking it's going to raise the capacities of the truck to a C30.
Hard
