C, K, R, V... What Do They Mean?!
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Hey guys. Im still new to the square body and Im trying to figure everything out I can!
When I went to register my ttruck, I noticed it was called a R30. I always thought it was a C30? So I went with it. Then I started wondering WHY! I googled it and came up with this:
Chevy C/K Trucks
C-Series Truck = 2 Wheel Drive (1960-2002)
K-Series Truck = 4 Wheel Drive (1960-2000)
C10 = “½ Ton” 2wd (1960-1987)
C20 = “3/4 ton” 2wd (1960-1988)
C30 = “1 Ton” 2wd (1960-1988)
K10 = “½ Ton” 4wd (1960-1987)
K20 = “3/4 ton” 4wd (1960-1988)
K30 = “1 Ton” 4wd (1960-1988)
C1500 = “1/2 Ton” (1988-1999)
C2500 = “3/4 Ton” (1988-2000)
C3500 = “1 Ton” (1988-2002)
K1500 = “1/2 Ton” (1988-1999)
K2500 = “3/4 Ton” (1988-2000)
K3500 = “1 Ton” (1988-2000)
Chevy R/V Trucks
R-Series Truck = 2 Wheel Drive (1987-1991)
V-Series Truck = 4 Wheel Drive (1987-1991)
R10 = “½ Ton” 2wd (1987-1988)
R20 = “3/4 ton” 2wd (1987-1988)
R30 = “1 Ton” 2wd (1987-1988)
V10 = “½ Ton” 4wd (1987-1988)
V20 = “3/4 ton” 4wd (1987-1988)
V30 = “1 Ton” 4wd (1987-1988)
R1500 = “1/2 Ton” ( Didn’t Exist!?)
R2500 = “3/4 Ton” (1989)
R3500 = “1 Ton” (1989-1991)
V1500 = “1/2 Ton” (Didn’t Exist!?)
V2500 = “3/4 Ton” (1989)
V3500 = “1 Ton” (1988-1991)
(Courtesy of 1Aauto.com)
This answered a few questions but not all. The Cs and Ks named trucks from 1960-2002, so why did they go off on a tangent from 1987-91 and give them names like R and V?
Thanks guys!
Mattchu60
Iowa
I think the renaming in 87' from C-R and K-V was to make those designations available for the GMT400 trucks which came out in 88'. That is my theory anyways.
chubble
Eastern, NC
Custom Deluxe K10
Yes, it makes it pretty confusing and difficult and I have argued with several Parts counter guys because mine is an 87 and falls into the V10 category on this technicality but I will always consider it to be a K10 because it is a square body and not a GMT400.
I think originally GM planned to introduce the GMT 400 trucks for the '87 model year, which is why the R/V thing started in '87. Ever notice that GMT 400 tailights have an '87 DOT stamp?
Then in '89, they updated the trim on the R/V series (styled like the new body trucks) so they started the 1500/2500/3500 thing then along with the updated trim.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
So why didn't they carry the R and V into the GMT400 generation lol.
Mattchu60
Iowa
They didnt carry them in because they wanted to keep using the c/k lettering. The R/V was because some squares were made at the same time as the GMT400 trucks. Like the Blazers/Suburbans/Crew Cabs. I think they all went to 1991. The GMT400 was to carry on the C/K designation, but they couldnt use that naming with a different (the old) bodystyle, so they were called R/V.
There was overlap in the lines, so the old line got renamed while the new line carried on with the C/K into the future. It made sense to do it that way.
FWIW:
Alphabet Soup
While the text above provides a reasonably accurate list of changes in the Chevy truck lineup over the years, the GM model numbers can be very confusing, so I'd like to focus briefly on the 1973-1991 trucks. Note that Chevy's part numbers may look like CC12345 or CK98765; I drop the initial "C" and focus only on the second letter as a model differentiator.
For 1973-1987, any 2WD full-size truck would be a C-series. K-series trucks are the four-wheel drive versions.
1/2-ton capacity trucks, including pickups, the Blazer / Jimmy, and Suburbans, are model 10, so a C-10 Suburban is a 2WD, 1/2 ton. Using this system, a 4WD Blazer is a "K-10" (even Chevy's paperwork calls them this) and not the "K-5" on the badge.
3/4-ton trucks (pickups and Suburbans) are model 20, and the 1-ton pickups are model 30. A K/20 pickup, for instance, is a four-wheel drive 3/4 ton.
In the split years of 1988-1991, things unfortunately get a little weirder. 1/2 ton trucks are now 1500 models, 3/4 tons are tagged as 2500 and the 1-tons are 3500. (Note that GMC started this in the late 70's, but Chevy took a few years to change over.) However, the 2WD/4WD designator depends on body style.
The new body style (regular and extended cab pickups) keep the "C" and "K" designation, so a K1500 in these years is 4WD with the IFS. The old body style (the Blazer/Jimmy, Suburban and crew-cab pickups) have an interim "R" and "V" designation (for two- and four wheel respectively.) A 3/4-ton Suburban is therefore a V-2500 and has a very solid front axle.
Therefore, those of us with these inbetween trucks must be careful to specify "I have an R/V truck and not a pickup" when obtaining parts. I had a devil of a time finding a front receiver hitch for a 1990 Suburban because folks assume (incorrectly) that parts for a 1990 pickup would fit. It may be easier to verify that parts would fit a pre-1988 pickup (old body style) as well as your later-model vehicle.
On the baby Blazer side, these trucks were often sold as "S-10 Blazer" or "S-15 Jimmy". Note that the S-10/15 desgination only applies to 2WD versions; 4WD versions were actually coded as T-10/15. Hats off to the General for making things unclear as always.
roadwolf
France
Rodolphe
silverado 10
and to complete this strange naming, the checy squares weight capacities were designated by the figure 10,20,30 whereas gmc used 1500,2500,3500.
a chevy k20 silverado* is the conterpart of the gmc 1500 sierra grande or high sierra depending on the year for the trim level .
*the trim level silverado of the square body, was re-used as the commercial name of the truck by chevy starting from 1999.
Danger Dave
