Bvllsh!t on craigslist.
Status
Not open for further replies.
Moderator Administrator
Huh. I guess all the CUCV's I've seen have required a PTO, because they've all had the 205.
Why would they build them with a 1-ton frame and axles, and then use the weak 208 t-case?
The NP208 is NOT weak as many think. It's just no a bullet proof unit. I'm sure the reason for the NP208, is the gubment was more concerned with a deeper crawl ratio which the NP208 does, where the NP203 and NP205 are pisspoor in the crawl ratio area.
Stroked
Beloit, Kansas
Jared
That's what everyone tells me, but I have 2 parts trucks with bad 208's. One has a broken chain and the other has a giant hole in the side of it.:Grenade:
My GMC just had the 208 replaced a couple years ago when my cousin still had it because it blew apart going down the highway. And I helped a buddy change one in his dad's pickup last fall because it stretched the chain.
I will say that I've never personally had a problem with one. :shrug:
8T6K5
AZ
L98 350 TPI
Dont encourage me. Already texted the guy, has a D60/14BFF...and the wheels, everything else is sold for change.
Go fer it. My dad's wife is in Phx visiting her daughters. I can have her drive your K5 back for me.
Moderator
Tell me if you notice anything wrong with this one... :wtf:
http://www.nextechclassifieds.com/listings/view/495598/
It looks like somebody went crazy with Rustoleum. Probably not, but it looks like it, lol.
I always assumed because they wanted the same drivetrain as found in the m1009. More parts that could be swapped if needed.
Stroked
Beloit, Kansas
Jared
That makes sense too
Sent from my iPhone 4s using Tapatalk
8T6K5
AZ
L98 350 TPI
Status
GRat
