Irishman999
- Jul 30, 2010
- Safford Arizona
- Jason
- K-1500 High Sierra
I read about the rivets a little on a previous forum, they are definitely a security feature. I think if you try to drill them out they just spin, they are also fragile. Some I have seen look like normal rivet heads though. If you are really carefull you could just cut a square around the vin, set it in place of the vin your changing out to and tac weld it in place. With the dash pad in place you should be completely in the clear.......
I doubt anyone would investigate into it very much since its just a Blazer, if you tried it with say a 69 camaro in great shape they might check to make sure everything is legitimate.
Most likely just as easy and 100% legal to just get a title for it.
I know you're kidding but a burb tag on a K5 would be WAY too easy to snuff out
