bushings & steering
Supersoaker
Littleton nc
Donnie
6.0 ls
looking for your suggestions
who has the best deals on bushing kits ??
what type are you using ??
need
control arm upper & lower
ball joints upper & lower
core support , cab , bed, leaf spring
don't need trans or sway bar
inner and outer tie rod ends, adjusters , pitman arm
3in drop spindles
:hmm:
Supersoaker
Littleton nc
Donnie
6.0 ls
so far rock auto for
ball joints, and steering stuff :)
Camar068
Kentucky
10 yrs Air Force
Agree, I would expect to pay half the price of AZ, AA, and Orriely's using Rock Auto. And thats without the 5% discount we get. Do your research and make sure your ordering the right part the first time. It's easy to get turned around with vehicle models and what the previous owner has thrown in there that's different from stock.
Supersoaker
Littleton nc
Donnie
6.0 ls
getting rear spring and control arm bushings from Jarhead on here :)
and the rest from rock :)
I'm with ya camar068
Supersoaker
Littleton nc
Donnie
6.0 ls
Thanks Jarhead....:cheers: got it yesterday
Jarhead79
Mt Vernon il
Michael
Np, hope they work out for ya
CRM
Pasco, Washington
Casey
K2500
350 CI
You might check out the post in the Rock Auto section of our preferred vendor area. One of the posts will explain how to get into their heavily discounted (clearance) section. I just ordered 13 items and payed under $40 for the whole thing. Half the items were under $2. There was a lot of steering and brake parts available.
Supersoaker
Littleton nc
Donnie
6.0 ls
thanks will do :) just did a big order from them
CRM
Pasco, Washington
Casey
K2500
350 CI
Here's what I picked up in the clearance section for my truck
1977 CHEVROLET C10 PICKUP 4.1L 250cid L6
API 270074021 Control Arm Bushing
Wholesaler Closeout -- 30 Day Warranty $ 2.90 $ 0.00 1 $ 2.90
CONTINENTAL 15391 Belt
Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty $ 1.57 $ 0.00 1 $ 1.57
FRAM FV185A PCV (Positive Crankcase Ventilation) Valve
Wholesaler Closeout -- 30 Day Warranty $ 0.77 $ 0.00 2 $ 1.54
KEMPARTS 1436 Distributor Cap
Wholesaler Closeout -- 30 Day Warranty $ 2.86 $ 0.00 1 $ 2.86
PRO-GAUGE FB59 Crankcase Breather Element
Wholesaler Closeout -- 30 Day Warranty $ 0.25 $ 0.00 1 $ 0.25
SPLITFIRE WS6515 Spark Plug Wire Kit
Wholesaler Closeout -- 30 Day Warranty $ 6.81 $ 0.00 1 $ 6.81
STANDARD MOTOR PRODUCTS VC258 Distributor Vacuum Advance
Wholesaler Closeout -- 30 Day Warranty $ 5.65 $ 0.00 1 $ 5.65
STANDARD MOTOR PRODUCTS DR319X Distributor Rotor
Wholesaler Closeout -- 30 Day Warranty $ 1.19 $ 0.00 1 $ 1.19
VICTOR REINZ C26544 Thermostat / Thermostat Housing / Water Outlet Seal
Wholesaler Closeout -- 30 Day Warranty $ 0.50 $ 0.00 1 $ 0.50
WAGNER H6024 (H6024:p) Headlamp Bulb
Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty $ 3.81 $ 0.00 2 $ 7.62
WIX 33051 (33051:p) Fuel Filter
Wholesaler Closeout - Private Label Pkg. - 30 Day Warranty $ 0.51 $ 0.00 1 $ 0.51
Shipping Ground $ 8.99
Order Total $ 40.39
Visa -$ 40.39
Balance Due $ 0.00
74 Shortbed
Good deal there..
