Brake Booster Spacers
64stingray
El Paso
Ray
1978 GMC
K2500
Hello-
I need the following brackets/ spacers for a custom brake booster conversion (1970 GMC) I am doing. These fit between the bracket and the booster. Does anyone know where I can get them?
I already have the special bracket so I don't need that only the spacers.
-They are 4.5" tall
-hole diameter is a little under 7/16" (3-1/2" apart)
-plates are 3/8" thick
Thank you,
Ray Perez
[email protected]
El Paso
Honestly, I'd make those myself before I paid for a set. It'd be easy with a chop saw and a drill press, or just a little more time-consuming with a cut-off wheel and an electric drill.
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
X2...probably better just to buy some the metal stock and fab in your garage. If you outsource the machine mork it will definitely be much more $$$ They should be rather simple to make yourself, especially since you have all the dims.
highdesertrange
kalifornia
mike
k30
x2 make them yourself. highdesertranger
ldmyers3195
