body lines dont line up.
86chevyk20
Buffalo
Liam
how do you tell if your frame is tweaked?? My bed isnt bolted down yet but my cab and bed line dont line up. On driver side the cab is a bit lower than cab. can body shims fix this?? but again its not bolted down yet because i gota take bed off again. fix??
crazy4offroad
Equal Opportunity Destroyer
West BY-GOD Virginia
Curt
K-10
350/SM465/NP205
Check your cab mounts, chances are they're worn out. It's like a rubber bushing between the cab and frame, there's 4 of them, 1 near each of the corners.
86chevyk20
Buffalo
Liam
there all brand new.
crazy4offroad
Curt
K-10
350/SM465/NP205
May have to park it on a level area and measure from the ground to the bottom of the rear cab mount brackets that come off the frame. One could be sagging or something. You could stack a few washers to make up a small amount but I wouldn't do much, it would throw the others out of whack.
86chevyk20
Buffalo
Liam
so how would i measure it? my driveway isnt that level lol i mean its not horribly off maybe a inch but its anoyying but again i dont even have the bed bolted up. im just kind curious
86chevyk20
Buffalo
Liam
in these pics you can see my problem. the passanger side is pretty much ok.. lol the driver side is off.. help?
Swims350
Logan WV
none
rear cab mount area is damaged or the bushing is worn out. maybe even the floor support on that side. As for the PS looks like the fender up front just needs raised up.
Buy yourself a Burb or K5 and you won;t have to deal with it, :waytogo:
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
John, I should show you a pic of my rocker panels...and the truck has never been hit.
TBSS GUY
