Blower works on high only
Usmczo6
New york
Alan
V30
Fellas I have a blower motor that is working on high only, I have not tried to diagnose anything thought I would ask on here first, I let it run for a while today after 5 minutes it started to make a squealing noise. I turned it off, turned it back on it went away, the heat is working the defrost is working, but the four position switch is only working on high, is this the blower motor or the switch?
350 w/203
You are going to need a DMM or test light before we begin to diagnose it.
Have you looked up the schematic in the GMSB Tech Section?
animal
Moderator
Lee
c10 silverado
350ish
When I had that issue it was the resistor. I had one sitting here so it was easy as I just plugged in the new one and it worked.
Catbox
Peter
C20 Silverado Camper Special
We are having the resistor issue now on our truck as well.
We just made a junkyard trip to find a couple of them as well as some other odds and ends.
Usmczo6
New york
Alan
V30
I have the Chilton's manual,
Moderator
Probably a resistor failure. You could diagnose it, or just put another one on it. In this case, I don't think anyone would judge you for just throwing parts at it, because it's cheap and usually the culprit.
A visual inspection is a must though. Check the blower fuse and look at the resistor connector for any melting or burning.
78C10BigTen
pennsylvannia
C10 BIG TEN
Id first say resistor, then the fuse holder over near the bulkhead (that was my problem) or the connector from the blower to the relay, they tend to melt.
Usmczo6
New york
Alan
V30
Yeah I figure I'll throw a resistor in they can't be too much, I appreciate the quick responses. This is a different topic but you guys are pretty knowledgeable,I don't think my electric choke is working on my quadrajet with the 454,any ideas how to diagnose that I have a multimeter I have a test light, I'm pretty mechanical, but I have no idea how to test if the electric choke is working how long is it supposed to get power for etc, I basically have to pump the truck four or five times and 50° weather, and then hold it steady about 1500 RPMs with my foot, for a minute before it'll idle on its own, and it still takes 15 minutes to get up to about 200° operating temperature,which I'm not complaining about but I feel like in the winter time I'd like to have heat a little sooner than that
Moderator
The choke coil should have a 12v supply whenever the engine is running.
Moderator Administrator
Resistor Failure. I had that problem on my 65 GMC. Turned out to be a broken spring. I put on rung into another and reconnected the spring. It changed the low setting speed a little but it fired it back up with Low and Medium again.
Usmczo6
New york
Alan
V30
Looks like this thing is toast!
350 w/203
Only an Ohm-meter will tell you for sure.
Kane Bittner
Cape Coral, FL
Kane
Sounds like a bad blower motor resistor. Here’s a link to an example one.
The “squealing” is usually a dry bearing on the motor. Easiest fix is just replace the motor.
Good luck.
Usmczo6
New york
Alan
V30
Just a quick update, they finally got the correct blower motor resistor in at the local auto store, I put it in works 100%, the flange is a little smaller than the opening I'll just silicone around it, thanks for the help
bajadiver
