Blend Door Panel
Tank6x2
You’re Awesome Know That!
Lifetime Supporting Member
Edmonton Alberta Canada
Kurt
C30
350, TH400.4:10 gears 2WD
Anyone have a pic they could throw up of their blend door - bottom side interior right at kick panel - looking to see how panels are positioned or how it came from factory - without the blend door installed/ if possible inside the rain tray runoff
The blend door is inside the plenum, behind the glove box. Do you mean the door in the kick panel for the max cooling / recirculate function?.
Tank6x2
Kurt
C30
What keeps water from coming in - not my photo
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
There's a seal on the kick panel insert. Just goes around the "tube" and pushes against the sheet metal. A little silicone doesn't hurt either.
Tank6x2
Kurt
C30
Really thought there was something missing
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
I thiiiink they're reproduced, I'm not positive though. Any of the big name sites should have it if it does exist.
mo4154
