Best way to ID transmission
DEMONIAM
central nc
TONY
c-10
I've inherited a 1976 c10 short bed, but have not done anything to her in my few years of ownership. I finally got her to crank, but noticed that the transmission seal had burst/leaked. Ready to order a kit, but I have no history on the truck (other than the engine was "replaced"), and no history on pre-90's mechanical work. Is there a way to identify the transmission, before ordering a seal/filter kit? I can grab pics later today.
73c20jim
Tombstone, AZ
Shape of drain pan.
Poppy 87
Bloomingdale GA
R10 Silverado
If the vacuum pipe is routed to the side of the case near the fluid filler tube, it's a TH400, if the pipe is at the passenger side rear corner of the transmission case it's a TH350
Sent from my XT1254 using Tapatalk
Dons79C10
