Bendix 2231532 BMC
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I’m wanting to rebuild or replace my brake master cylinder. Nothing malfunctioning, but for the sake of preventative maintenance.
There are three listings for master cylinders from Napa on a k30. I think the last one, p/n M2533, is the hydro boost/diesel option; but the reservoir cap states “DOT3 ONLY”:
If I look at my brake master cylinder, it is p/n 2231532. My reservoir cap states “DOT5 ONLY”
When I google those they go for close to $500. What gives? Am I missing something?
Finally, is the a rebuild/seal kit specific to dot5? I was always told that if a system is thoroughly flushed, it can run any fluid type ie dot 3/4, dot5 and dot5.1. Albeit extremely difficult to fully remove all of one type of fluid.
73c20jim
Tombstone, AZ
Stay away from DOT 5. DOT 5.1 is OK. I don't remember why. Maybe someone can help.
ajd89
Central Michigan
andrew
I thought dot 5 was the way to go...
73c20jim
Tombstone, AZ
Craig 85
Nashville, TN
454/TH-400/NP205
I bought the M2533 for mine. I don't like using rebuilt M/C's. I still have the M/C that came on my truck and it has the same casting number, but the pre-fix is 128. There is some other casting to the right of the main cast number, but it doesn't have enough detail to read.
I've had 5 GM trucks up to 2004 model year with hydro-boost. All of them ran DOT-3 and I've never had any issues even towing travel travelers over the Sierras.
CSFJ
I picked up an extra MC for my truck off ebay. found some new old stock surplus pieces. might be worth a look.
fastwagonfab
