Bench seat bolts.
mavtricks71
az
mike
I NEED 2 bolts that hold in my bench seat for my 1986 k10. They stripped out and I want OEM original bolts. I can Paypal you if you can throw them in an Envelope and mail to me.
mavtricks71
az
mike
HEY NOW SOMEBODY HAS TO HAVE A TRUCK THEY ARE PARTING? :D
75gmck25
Northern Virginia
Bruce
If you have two stripped bolts, then you must have a couple more good ones so that you know the right size. Just take them down to HD or Lowes and buy a grade 8 bolt with the same threads and length. If there is an issue with the threads in the truck, then use a little longer bolt and a grade 8 washer and nut under the truck.
Bruce
You can buy new bolts that are an exact match for stock. Free-spinning washers, pointed tips and everything. NAPA, Fastenal or many other parts stores will have them or can get them.
mavtricks71
az
mike
ok cool ill try it
trukman1
Gary
K5 Blazer
5.7 L (350)
If that doesn't work try K5 PLOWER on CK5.com He has a K5 he's parting out and may be able to help you if you want factory bolts.He's a friend of mine so just trying to help you both out.
KilgoreTrout
Pennsylvania
Dylan
350ci
I broke two seat bolts getting mine out the other day.
If you can get the threaded parts out of my cab floor, you can have them.
Hard
