battery tray difference
marks86
Latham, NY
Mark
12v Cummins
all 81-87 trucks had battery trays on the pass(RH) side, is a LH(auxiliary) side on any different
I'm going off memory here, but I think the tray is the same, it's the support bracket that is different.
friscobob
Sutherlin Oregon
Bob
C 10
Just looked at my '81, the battery tray and support are a welded unit and looking at the mounting holes I'd say the LH one is a mirror copy of the RH. The inner fender even has dimples where you need to drill mounting holes.
Bob
marks86
Latham, NY
Mark
12v Cummins
I just went ahead and bought a LH battery tray from LMC. Part number is different so we will see, besides its hard to find a battery tray that the bottom bolt hole is rotted off of around here, will put pic in my build thread
thanks for the answers guys
MadOgre
NA
NA
NA
NA
NA
The trays are different slightly as well as being opposite to each other. The left outer fender does not have welded nuts to attach the tray so you must use 2 bolts and nuts and squeeze your hand in to the inner part of the outer fender to fasten the tray to the fender.
There is a dimple for the upper bolt to attach to the inner fender. Drill this hole and then fasten your tray to the inner fender where you drilled and the outer fender with your 2 bolts and then mark where the hole will be for your lower bolt as there is no dimple to go off of for that lower bolt. Then remove the tray drill the lower bolt hole and then reassemble.
slowgo
wa
Blake
V3500 3+3
454, nv4500, 205, 4.56 rp
They are different. I just installed them on my v3500. There's dimples where to drill but you'll have to use a nut on the inner fender if your truck didn't come factory with aux battery
Shak379
