bad wheel hop
bigredrig
canada
pop
Hi everyone this is my first post there but been reading and learning for years.
I cant find any info. on the problem im having with wheel hop when the truck is cold.
little info. on the truck, its a stock 1984 k10 with inline 250 6 with newish 33" tires, and sm465 tranny.
The problem is when i start the truck after 2 hours of sitting it will wheel hop in reverse or forward. It will stop after a while but it seems that the rear end whats to rip off the truck?
any ideas??
highdesertrange
kalifornia
mike
k30
I think you need to define wheel hop a little better. is it doing mini burn outs like every foot? or is the whole truck lurching? does it do it just from a standing start or also when it's rolling? highdesertranger
350runner
tx
Ceasar
Rear brakes too tight or gears out of spec. Just guessing
Carb'ed Vortec 350
Clutch chatter?
friscobob
Sutherlin Oregon
Bob
C 10
Worn out shocks and/or other suspension parts.
bigredrig
canada
pop
thanks for the responses.
the wheel hop is every foot from a stand still for the first to 3 feet. Once moving all is good until i stop again, will do this for the first 5 minutes then goes away until i park the truck for more then 2-3 hour and then it starts wheel hoping again.
bigredrig
canada
pop
thanks everyone.
so Does that mean its going to get worse? because its only happening for the first 3 minutes of every drive when cold.
Carb'ed Vortec 350
My initial response is "Yes". From what I understand, clutch chatter happens from oil or some foreign substance getting on the flywheel which causes it to skip. A worn clutch assembly ( flywheel needs turned/replaced; clutch disc worn; pressure plate worn ) may cause it too. If you replace the clutch, get a matched set, they operate much better than buying the pieces separately. The set will come with the disc and pressure plate and an alignment tool. They cost about $150, and getting the flywheel turned is probably $60. And make sure you don't get grease or oil on the components when you install them. I always spray down the flywheel with brake clean and wipe it down well, same with the pressure plate.
There may be other answers that come in regarding what causes clutch chatter. I know I hate clutch chatter. I want my stuff operating smoothly.
firebane
Calgary, AB
Curtis
thanks everyone.
Sounds like your clutch is starting to go.. Either springs, disc, or flywheel.
Carb'ed Vortec 350
Oh yeah, with a small brush, paint a thin layer of white lithium grease on the input shaft and a little inside the pilot bushing and the fork where it contacts the throw out bearing. Just a little, it helps with assembly and with clutch action.
highdesertrange
kalifornia
mike
k30
don't forget to lube the throw out bearing, the groove on the inside. highdesertranger
bigredrig
canada
pop
Thanks for all the reply's!! Ill get to it maybe next weekend and let you know if all is good.
More than anything, I'd suggest a saturated clutch disk. Possibly a rear main seal leak?
Wheel hop is almost impossible to be a problem with a 250 6 cyl, so I say the problem is something other than wheel hop for certain. Clutch chatter is the most likely problem.
sever
