the cover is aluminum and the motor mounts run a rod back tothe cover and bolt on so I want to keep it.I'll just take a grinder to it or cut it to fit.JUst wasn't sure if there was a higher purpose for it that I wasn't aware of.Thanks for the input
Yeah, if it's a 4x4 with the aluminum cover and support rods then it is definitely needed.
The tin and plastic covers are the ones I'm not afraid to leave off. To me, having the flexplate and torque converter exposed is no different than the exposed crank pulley or the drive shaft.
I dislike,with a passion,changing starters,especially if it caused from an early failure due to parts not being in place.![]()
I've never had an issue from it. Although I did once instal the tin cover so the leaky rear main seal didn't fling oil all over the place![]()
