Anyone use flexpipe?
Carb'ed Vortec 350
how about this? bend your flex pipe to the needed shape and length, run down to the local exhaust shop, have them make you a pipe that size, bent and length, expand it to fit over your current pipe or make it fit inside, I reccomend, over the lead pup and inside the tail. Take it home and get two clamps, and be done. it'll last for a long time.
Our local shop only charged me 280 to run pipes from the headers back 2-1/4 and install mufflers and tailpipes, 400 is alot.
I know getting cats aint cheap though they are a hundred a pop for new ones here, or gutted ones run 35 each.
400 is a lot. The shop I went to wanted to charge me $300 to run about 4 feet of pipe and add the muffler in its orginal spot. Single exhaust!
Some good ideas were mentioned here. I agree, stay away from the flex pipe.
chengny
I think they call it "bellows style" flex pipe. Similar to a corrugated expansion joint used in steam piping
Christian Nelson
Wisconsin
Christian
K15
Stuff I used years ago burned through within 6 months, I used it to get through the transfer case cross member. I had it blow out twice, then I bought bent pipe, cut and shaped to fit like an "S" curve to fit just right. I was dumping from headers into this, then glass packs, and straight pipe all the way back. Of course, the headers rusted about a year after that. MAN, I hate salt being thrown on the ice!
I wouldn't reccomend for anything other than temporary, or to use as a template for forming solid pipe with.
I believe I was using the non stainless stuff.
87ChevyR10
Kansas
NA
NA
NA
I'll have to call around and see what quotes I get from surrounding shops. It can't be too much considering all I need are a pair of header pipes to connect the rest of the exhaust. Who knows, maybe I can find a shop that'll do the work w/o installing cats.
350runner
tx
Ceasar
Cats? what are those? Lol
Moderator Administrator
The only things I have taking a dump behind my cab is Dogs !!! No Cats at all.
I do like the idea of keeping a flex pipe as a tool for a template and take to an exhaust shop to make a solid pipe.
Smith
NW Ohio
No
I used flex pipe like this http://shop.advanceautoparts.com/p/...=google&utm_campaign=gpla&utm_content=5600049 on Honda Accord I had, worked for that car but then again its a little smoother idling and driving than truck. I wouldn't expect it to be a permanent solution and would intend to down the road get it fixed but its 8 bucks, why not give it a shot and wait until you can afford a full redone exhaust or to get the shop to run what you have?
Moderator
I used a section of that stuff once. I think it was a 2-foot piece that I cut in half and put on the car. It made it a few months before it broke, then I replaced it with the other half I had saved before. IIRC, it started leaking a few months later and I replaced the exhaust.
Smith
NW Ohio
No
Yeah it by no means is a permanent solution but it may get him rolling down the road for a while. I did this in the winter time so it basicly had two Ohio winters it went through and lasted.
87ChevyR10
Kansas
NA
NA
NA
It's not like my current setup is failing; it's just not 100% right. The driver side exhaust angles off to the side while the passenger side is true as it should be. I dunno what the deal is with the crossmember pipes and why they didn't allow a proper install.
Skweegle89
Oklahoma
Idk how it will hold up on a puckup, but it's used on every peterbuilt out of the factory and seems to hold up for several hundred thousand miles. I have never seen it used on a personal vehicle, but it's not like your out a bunch of money of it only lasts 6 months.
MadOgre
NA
NA
NA
NA
NA
Ya but the piece that goes from the turbo to the y always blows out on petes
nixon22
