anyone know where these vacuum lines go?
Scott
Fresno
Scott
K1500
i know it mounts in air cleaner but what do the 3 vacuum lines connect to?
thanks
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
thanks
The line at the top, on the left side goes to the secondary vacuum brake. the one below that, goes to the Bi metal temp switch thats under the air cleaner, that controls the heat riser door.
The single line on the right T's into a vacuum line coming from port N on the back of the carb, which is manifold vac.
Scott
Fresno
Scott
K1500
thanks alot sir
Scott
Fresno
Scott
K1500
so this has nothing to do with the main choke pull off? Do you know where the main choke pull of vacuum line comes from?
Jims86
Patterson,Ca
5.7 TBI
That line comes off of a metal T line on the fron pass side of the carburetor...kinda near the top of the carb. The branch off is pointed right at the pull off.
Scott
Fresno
Scott
K1500
oh ok got it you know your stuff !
bigcreek
