Anyone ever seen or messed with a GM 4L30E?
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Things a whopper to come out of a Honda passport.
(beer bottle for scale)
Next pic is it next to a GM 4L60e.
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
See if you can adapt it to the GM product of your choice. It probably has a half a million miles on it before it went bad. Lol
Vbb199
Salisbury NC
Vince
Weirdly, the bellhousing pattern is different than standard GM.
250k on it.
Fluid is getting dark dark read, slightest shortage in fluid and it slips.
I'm gonna do a full rebuild on it.
Moderator
GM made some automatics for BMW too. I have no clue what the model name was.
Vbb199
Salisbury NC
Vince
I was just looking at that on the Web.
BMW's GM 4L30E
Vbb199
Salisbury NC
Vince
Tore down the transmission tonight.
Odd tranny.
It's got 2 planatary gear sets.
1 for 1st, 1 for 2nd.
2 pans, 2 valve bodies.
2-3 or 3-4 gear band is at the bottom of the transmission.
1st gear uses its own planatary set, pan, and valve body., hell it's got its own section of the transmission.
78C10BigTen
pennsylvannia
C10 BIG TEN
From a passport... a friend of mine has a honda pilot, i wonder whats in that???
Vbb199
Salisbury NC
Vince
Im not sure.
The passport really has gained a whole new level or respect from me.
Has a HD d44 rear, not sure about front diff, but it's bigger than the s10 front diff.
(the old diff, not the dana 60 LOL)
Rear is 3 link, geared 4.30 with limited slip.
3.2L isuzu motor that just won't quit. DOHC
GM 4L30E.
Transfer case I didn't take the time to identify. I assume new process.
It's just high and low range.
Vaccuum operated 2wd/4x4. Also has "winter drive" mode, which makes it awd.
It's got some sort of proprietary adapter and pattern. Not just a standard 6 bolt circle or whatever.
Essentially you can't clock it. It's doweled in place.
Vbb199
Salisbury NC
Vince
I will say, in 1st gear, low range 4x4, it feels like it's got a 3:1 ratio, or even lower lol
Moderator
The Passport was an Isuzu Rodeo. It is a perfect example of badge engineering. A Pilot is front wheel drive based, and a full on Honda product. It did/does use a Honda trans too.
Vbb199
Salisbury NC
Vince
Oh I know. I have a 99 isuzu rodeo I have for parts, and her 99 honda passport... Same car, different badging
Vbb199
Salisbury NC
Vince
Hard to decide. But I think this section is the hardest.
It is 2nd and 3rd I do believe.
Working on section #2 for 1st and 4th.
78C10BigTen
pennsylvannia
C10 BIG TEN
Wrong post, cant find the correct one!! Just like an s10 and an hombre. Where does the isuzu pup fall??
Moderator
The S10 and Hombre had several differences like the grille, headlights, fenders, bedsides and the rear bumper trim. The Passport was really identical to the Rodeo besides the emblems. Iirc, even the grille was the same?
I believe the Pup was simply an Isuzu. I never really kept after the little furrin trucks though.
Scrambler-Cafe
