Anybody try AT-205 for leaks?
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Has anyone used this, and what were the results? It claims to stop oil leaks by reintroducing plasticizers into oil seals rather than just swelling them with petroleum distillates. I generally don't take shortcuts like this, but I'm dealing with a leaky rear main seal on my wife's '04 Accord. To get to the seal requires removal of either the engine or transmission, and that's beyond my pay grade so to speak. I've called around to a few shops and most don't even want to do the job, while the others are telling me to sell the car or just let it leak. I hate to get rid of it, it's a garaged one-owner in excellent condition with 170k on the clock and new Michelin tires.
So, in researching repairs I see this product mentioned as an alternative with a good success rate. I've never heard of it but wanted to get opinions from the GMSB crew before trying it.
Sad Sack
Nebraska
Goober
C15
Hard to find any bad reviews on it.
Scotty Kilmer likes it:
Moderator
Now, I've never watched any of his videos but, to me, that dude comes across as an opinionated nut job. Yes, I realize that I'm "the pot calling the kettle black" because I just stated an opinion too, lol.
dd1990
Oxnard, CA
Suburban 1500
Ive used this on a rear main seal leak and it helped but eventually after a few weeks oil started pouring out of the rear main. I believe this product eventually expands seals too much
Sad Sack
Nebraska
Goober
C15
ATP products used to be highly regarded, hopefully still are.
legopnuematic
Licensed Junk Dealer
MO
Spencer
In the early days of his YouTubing his stuff was mostly ok, pretty basic stuff, nothing earth shattering. I haven’t watched for years but pretty much all click bait thumbnails and titles these days. He also passes away at least four times a year.
He has definitely over time gave or endorsed some bad advice, like using compression fittings on a brake system.
But for YouTube, the algorithm doesn’t know if a comment is positive or negative, same for a share, people are probably more likely to interact/comment on something controversial than not. As far as what YouTube sees, a comment is a comment, which is an interaction, which is favorable and will push the content farther to more people.
Basically, being that way and regularly stirring up controversy makes for a more successful ‘YouTube career’ than just being normal. For someone who has established that reputation.
Supporting Member Army
Is it the v-6 or the inline 4? In my experience, hondas almost never leak from the main seal. It is far more likely to be the oil pan gasket leaking.
Also, never use a gasket sealing compound like this. They work by swelling the seal, which is actually just making the rubber loose and soft. It MIGHT close off the leak for a short period of time, but then it will most likely cause the leaking seal to catastrophically fail or other seals that previously weren't leaking will now start leaking shortly.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
It's the V6. I cleaned the bottom of the engine very well and went for a drive. Oil is coming from the inspection plate area, which has to be the main seal, sealant on the rear plate that holds the seal, or the small o-ring inside the rear plate. Doesn't matter which one it is, the repair still involves spending $2k on a $6k car. I would do the repair if I could find a shop I trust, but none seem willing to tie up a bay for 2-3 days.
I agree with Bextreme, most of the quick fixes cause long-term problems, but this product claims to work differently by not bloating the seals. I just found a comparison test by Project Farm and this product came out as his number one pick.
Hmm. Keep looking for a mechanic? Try this quick fix? Or give Carvana a call.
Chevy 88
Canada
f7t6
GMC
I have used AT-205 for years. Its great stuff.
It does not cause rubber to swell, the way other stop leak additives do.
You can easily test this if you want. Just take 2 brand new seals and soak one seal and not the other. No swelling will occur.
I have found that it has a very high success rate.
I have used it to fix rear main leaks and it worked every time. It will not cause more problems.
Seals have a chemical in them that make the rubber soft and flexible. With time, that chemical evaporates and the rubber become hard and no longer able to create a seal. AT-205 is simply replacing that chemical that was lost, and the rubber becomes flexible again so that the seal spring can do its job.
I use it in all of my systems as preventative maintenance. Trans, engine, axles, power steering etc. Just don't use it in the brake system.
Sad Sack
Nebraska
Goober
C15
Ah crap! I just poured a bottle in my brake reservoir to keep my wheel cylinder boots and caliper piston seals healthy and windshield washer reservoir to keep my pump seals happy. Going to go hide and cry now...brb.
Matt69olds
Central Indiana
GMC 1/2 ton
455 Olds
I can’t stand Scotty Kilmer!! The fact he endorses something makes me question the product.
Trying to fix a leak with a seal reconditioner is like putting a band aid on a gunshot wound.
If you really want to try it, pour it in following the instructions, drive it a while, if the leak stops, change the fluid. Get the seal conditioner out. The reason I say that, I have taken apart enough transmissions that have had stop leak put in them, all the seals are swollen 3 times the normal size, and spongy. Let the stuff soften the seal, then get it out of there before it does real damage.
Moderator
Imho, keep looking for a good mechanic that is willing to work on older stuff. I know how you take care of stuff and I know that Honda is in good shape. It's worth the repair, even if you have to pay someone else to do it.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
An older car basically no matter the repair, engine/trans, you'll always be money ahead getting it fixed instead of buying a new car and making payments. UNLESS you can pay for a new car in full, but if you can do that you can afford any repair basically.
New cars suck! Wait a few more years and see how much worse the new car situation gets.
Sierra_87
