antenna extender?
jastewart25
Louisiana
Julie
i have a windshield antenna in 1985 k10. (not sure if it is original)
previous owner had installed a single din aftermarket radio/cd player. i purchased mp3/bluetooth radio only so the entire radio is shorter. the po has the correct antenna adapter but it won't reach my radio. about 3 inches too short.
are there any antenna adapters out there that are longer? & where do i get them from?
also, i can't confirm antenna works as the po's radio did not pickup stations but it could be radio so i replaced it.
if glass antenna with longer adapter doesn't work, what is my next best option?
thank you all!
highdesertrange
kalifornia
mike
k30
you don't need to replace the whole cable just put a short cable extension in. an electronics store by me sells them. I think the shortest they sell is like 6". but they are available just search around. highdesertranger
I would think any auto store would have them.
GTME94
Metro Detroit/Holland, MI
Terry
C2500 C6P Camper Special
454/TH400/14bff 3.73
I got one at Advance or Autozone this summer when I installed my new radio. They had a short one about 6" and then one about a foot or maybe 18" or so long.
jastewart25
Louisiana
Julie
sorry, for some reason i didn't see your replies. thank you for responses.
turns out i ordered an extender recommended by crutchfield (where i ordered my radio from)
the extension cord female end doesn't fit the male end of the cord that is already in there. talk about a bummer!
it seems the male end on the antenna currently installed is smaller than most. does anyone know what kind of antenna cable this would be so i can look for that extension?
i thought all antenna cords were the same. guess i was wrong!
firebane
Calgary, AB
Curtis
antenna cords are not the same. This is why when you buy an aftermarket stereo you may need to buy a "<insert manufacturer> to stereo" adapter to fit properly.
GM/Chevy has a tendency to be smaller than normal.
jastewart25
Louisiana
Julie
all set...finally!
thanks for advice.
i used this antenna extension cord to fit aftermarket antenna cord from po to my digital radio
Metra 44-EC18 18-Inch Antenna Extension Cable
K5Chris
