Another power steering pump question.
Shilaeli hugger
Ohio
Burdaddy
V20
My neighbor is letting me strip her 95 half ton v6 for anything i can use. I was looking at the power steering pump. The whole belt drive is set up the same as my 87. Would it work on my truck? Anything else i should grab before it gets hauled away?
yevgenievich
Viktor
sad
very sad
less sad
complete front engine accessories, wheels and maybe the seats.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
If it has a Jeep XJ intermediate steering shaft, I'd grab it. More than likely doesn't, but the Jeep shaft has universal joints and the GM shaft has a rubber rag joint on the Saginaw steering gearbox end. If it's TBI, I'd grab all the sensors that are the same so you can have spares because sensor failure is as much a guarantee as death or taxes. They should all be the same minus the TPS sensor, and it won't have a ESC module on it if it's an automatic. If it's a manual, I'd grab the ECM. If it's an automatic, do not. Yours is TBI, right? Just wondering because I'm guessing you have serpentine accessory drive because the GMT400's came with serpentine.
Shilaeli hugger
Ohio
Burdaddy
V20
Yeah i have 87 tbi. Went over to check headlight harness on the 95 but dont think itll work. Got the headlights so far. Just wanted to make sure before i go tearin stuff off and end up with stuff i dont need. Hers is half ton so 6 lug. Cant use them. Gonna grab.positive cables. Found out my alt isnt even hooked to the battery! What the hell. No big deal i dont mind a project. Gonna rewire whole truck anyway.
Kipps5000
