another elco
yevgenievich
Place
Name
Year
Model
Size
I enjoy your build threads. Do you have a lot of time to work on them? Because you get a lot of **** done on a lot of cars. Or do you just get a lot if **** done in a short period of time? Lol
Thanks,
Always short on time and feel like everything takes for ever. Been dealing with old f150 lately as well swapping engine and having to pull the transmission couple of times for various reasons.
yevgenievich
Place
Name
Year
Model
Size
Bed piece installed. Some new ac ducting and speakers. Finally received new connector for fan selector switch that i need to install and dash pad can get installed.
yevgenievich
Place
Name
Year
Model
Size
Have radio left to install. Have one that only radio works and one that is fully functional. But have to take the good one out of a different vehicle that is getting a better one.
yevgenievich
Place
Name
Year
Model
Size
Decided to install the better radio. Actually sounds pretty good. This will be my only main daily for a while, so some working music preferred.
will make a pretty cool daily :)
yevgenievich
Place
Name
Year
Model
Size
It already been serving daily duties so far (no floors and all at the beginning). Now it is becoming more of a reasonable daily. Really kind of want to sell it before the paint completely fails. But it is now my only vehicle for my use(camaro is in pieces and trans am in paint). Added air bags last night in case need to move heavy things. It is nice to have a truck thing around.
yevgenievich
Place
Name
Year
Model
Size
Removing internal stops to open turning to 87* vs 60* 3rd gen f body set up.
You maybe can confirm, do the fast ratio boxes from the '85-'87 Z28's and T/A's with 15" wheels have different internal stops for sharper turning?
yevgenievich
Place
Name
Year
Model
Size
I thought all 3rd gens had same stops.
Steering box is back together. Caught lower radiator hose trying to explode.
If you were closer I'd buy it off you and daily it myself even if the paint does fail :)
yevgenievich
Place
Name
Year
Model
Size
Old rag joint for reference. With 3rd gen f body box elco became a different vehicle. A lot more inspiring steering, even with the rest of the stuff being old. Also found driver side lower a arm loosing hardware and loose. Tightened it secure.
yevgenievich
Place
Name
Year
Model
Size
Changed hinge pins on driver side. driver side door came from a different car at some point and window frame does not line up at all. Huge variable gaps around the top. Played with adjustment some, including bending the top channel some and added a seal on body side.
cmcqueen
