Annoying Key Buzzer Cure
dragstews
GMC-IH
Belleview Florida US of A
Jesse
Body 1954, frame 1975
R-100
406 ci SBC
Most people pulls the critter out of the dash cause it rubs them the wrong way ..
Years back I worked at a Cadillac dealership, can't recall how many buzzers I unplugged ..
Since I have installed a 75 Cadillac column in my old truck and it having the key buzzer switch built in, figured why not use it ..
The custom made buzzer I'm using can be programed to play a 30 second sound clip of your choice and it loops back to the beginning, keeps playing until you pull the key out or turn off the headlights ...
This was my choice for the chime ... If I get tried of hearing it can always download something else ...
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
!973 was a long time ago when this music was composed ...
It was the opening theme for a spook movie called "The Exorcist"
I like it cause it's light and airy, not screaming at you like most key chimes do ..
I may change it to this if I get tired of hearing it ??
.... (Or get spooked) ....
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Could pull a 30 second clip from "Hey Joe" ..
Being you can write over the existing program that's in it, it's endless ...
SquareRoot
The older you get the more you begin to appreciate those annoying buzzers & reminders. After 2 dead batteries, I found and installed a buzzer. No more dead batteries. They say your memory is the second thing to go. I can't remember the first.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
That looks like a GMT400 chime thing. This is a pretty cool idea. Did you do the mods? Or where did you get it?
dragstews
GMC-IH
Jesse
R-100
406 ci SBC
Programmable indicator - https://amzn.to/2Z5jmtx
USB to mini USB cable - https://amzn.to/3f7FI35
Relay - https://amzn.to/2ZI4Bfb
10k ohm 1/4 watt resistor - https://amzn.to/2ZNuf2h
dremel bit - https://amzn.to/3iErskz
transistor - https://amzn.to/2O2wys
Brosin core solder - https://amzn.to/2VVdOzw
heat shrink tubing - https://amzn.to/2Z3lxgU
soldering wand - https://amzn.to/2O45ARk
Helping hand - https://amzn.to/3hQr6pK
You can build it yourself .. links above is all the needed parts & tools ...
Follow Grim Repair's instructions and you too will have a key chime that's not so annoying ..
Tonimus
Phoenix
Tony
C10 Suburban
I fully support this.
blue10
