aftermarket sway bar mounts
heviarti
Emmett, Idaho
Buck
C25
383 Stroker
Does anyone know of a ready made full box sway bar bushing mount for the front end? It turns.out the left one is bent to crap on my pickup, and has pulled the sway bar out of its bushing on the control arm. I'm thinking about replacing them both with something heavier.
MadOgre
NA
NA
NA
NA
NA
You mean you bent the u bolt plate ?
EDIT: LOL I didn't see the "C"
heviarti
Emmett, Idaho
Buck
C25
383 Stroker
Yep, just 2wd. I can take a photo of the damage. I think it may be responsible for the intermittent vibration I feel at higher speeds.
MadOgre
NA
NA
NA
NA
NA
Ya post a pic
heviarti
Emmett, Idaho
Buck
C25
383 Stroker
Here are some pics of the issue...
highdesertrange
kalifornia
mike
k30
ouch, someone hit something good. get one from a junk yard or make your own. highdesertranger
MadOgre
NA
NA
NA
NA
NA
Ya I agree you will have to go to the junk yard with a 2lb BH and a cold chisel so you can knock the rivets off and punch to punch them out.
Then just bolt them in on your frame with grade 8 bolts
heviarti
Emmett, Idaho
Buck
C25
383 Stroker
Previous owner's landlord was drunk and put it through a ditch and fence and 'ripped the power steering pump off'. I was just curious if someone already made something boxed, rather than fabbing a boxed mount.
TBSS GUY
