Adding Intermittent Wipers
Kilian
Wisconsin
K
C2500 on its way to a K2500
My 83 GMC C2500 currently has the two speed, dash-mounted wiper switch. I see that there was a "pulse" option available as well. What is needed to add the Pulse system to my truck? I'm assuming it's not just as easy as adding the pulse switch...is there a module that is needed as well? Thanks.
gmachinz
Harnessworx Inc
Iowa
Jabin
Yes-together the module and switch is a plug n play replacement for your 2-speed setup.
Snoots
Roger
Jimmy Sierra
350 w/203
You may likely need to add the pulse motor.
78C10BigTen
pennsylvannia
Ted
C10 BIG TEN
Here is the intermittent switch and module for visual reference. Pretty sure its still the same between my 78 and your 83
boarder421
