A.C Dash Vent Replacement
hip2bsquare
Jake
1986 chevy swb
1986 chevy swb
sbc-5.3 ls
I want to replace the A.C. vents in my 1986 C10 A.C. truck. I am looking at just changing the "registers" only? Can the A.C. vent "registers" be swapped out without having to change the assembly (the black assy. the vents sit in that fits/Screws behind the Dash)? LMC sells the "vents" and the housing separately. i would rather not have to disconnect the hoses to each vent if I don't have to...
thanks!!
You'll have to disconnect the hoses to do so, the registers install from the backside
hip2bsquare
Jake
1986 chevy swb
1986 chevy swb
sbc-5.3 ls
Huck, thanks for the reply... I thought that was the case, but I thought I would ask incase someone had "discovered" a tip or trick... kinda like the 'ol hinge spring replacement trick.... LOL!! :D
THANKS!!
Sgt Gus
Mark
R20 3/4 ton
454ci/7.4L
Let me know if that replacing them keeps them from being all loosey goosey.
sunking
