90 burban acc/heat fuse blows
1990burb
wisconsin
mike
1500 sub
alright guys so this is my first post here on this awesome forum so bare with me please. so yesterday i charged up the ac in my truck and everything was good. nice cold ac. but the issue arose once i started to drive the truck down the road. so once i am moving the acc/heater fuse blows. along with the blower no longer functioning the speedo is also on that circuit and no longer works as well. so i replaced the fuse and as long as the truck is parked the ac works great no fuse blown. and same with the speedo as long as the air is off while in motion. any ideas of where i could be looking to solve this little conundrum? i sure would like to enjoy the ac while driving not just parked lol. any input and/or suggestions would be greatly appreciated. thanks in advance
1990burb
wisconsin
mike
1500 sub
my burb only has front ac no rear. I'm not sure if it does it with only the heater on i will check that out here in a few. changing the fan speed doesn't make a difference any speed blows the fuse if the vehicle is in motion while the blower is operating with the ac on thank you for the diagrams and trouble shooting guides i will put those to use today and get back. thanks again for the input
1990burb
wisconsin
mike
1500 sub
ok so a little update. the fuse only blows when the ac is on and the truck is moving. does not blow if the truck is parked. and does not blow if the heater or vent is on rather it is moving or parked. so i am thinking the problem has to lie in the ac circuit. i read something about the little diode on the connector for the ac clutch. it was suggested that i should remove that diode. but I'm figuring it was there for a reason and wanted to check here if anyone had heard of that or not and what the possible outcomes may be. once again thanks for taking the time to review my post and i look forward to any and all input.
350runner
tx
Ceasar
Try just unplugging the connector to the compressor.
At the firewall. That will eliminate any shorts in the entire run (from the firewall connector, down on to the engine, all along the valve cover and up to the compressor clutch):
350runner
tx
Ceasar
True, they both sound like good ideas.
Jleopard77
