'87 TBI 350 Troubles
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
got the ecm swapped over and it fired right up but the check engine light is rapidfireing like you said. i checked the PROM chips and none of the terminals were bent. is there something else that could cause this?
my dad started messing with the chips to makesure that they were seated properly and now it wont start and no check engine light. there isnt any light even when the key is on and engine off.
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Make sure they are not in backwards. The notch on the cip holder should be pointing to the right of the ecm if you are holding it with the plugs pointed up. make sure both chips are all the way down.
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
there in correctly
Jims86
Patterson,Ca
5.7 TBI
Well, I dunno what to tell ya...that rapid fire means something is wrong with the chip(s)
what are the part numbers on the new ecm?
Jims86
Patterson,Ca
5.7 TBI
OK...I would pay particular attention to both chips...CalPac could be upside down...Its the skinny chip.
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
im 99% positive that the chips are in right.
im going to put the chips back into the old ecm to see if it is a bad chip or if the ecm that i bought is bad.
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
put the chips back in the old ecm and there is a check engine light. i will warranty the new ecm.
Jims86
Patterson,Ca
5.7 TBI
Sorry your having so much trouble!
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
I know! its been more that 2 months since that truck has been running. atleast now we know that it was the ecm.
I called Rockauto this evening and they can only refund my money not send me a new one because they are out of stock:flipthebird: so my dad is getting one from a friend that he is working with this week. should be here in a week or so.
Jims86
Patterson,Ca
5.7 TBI
Thats good news. I have had good lick with Standard and A1 cardone remans. Airtex/wells is the best aftermarket...dunno if they do ecm's or not though.
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
Got the ECM....wrong kind
its from an 89, i thaught that they would interchange as long as it is tbi. guess not.
Jims86
Patterson,Ca
5.7 TBI
87 to 91 and some till mid 93...whats the one you have now?
Jake292
Fort Worth, TX
Jake
r10
350 efi, 700r4
not sure, the numbers are faded on the new ecm. The one in my truck is 1227747.
The one that i got from the 89 was out of a heavy duty 1 ton with a 454 and a 40l80. i think that the tranny is the reason why it is different.
gonna be looking at Pull a part in the near future.
Jims86
Patterson,Ca
5.7 TBI
Ohhhhhhhhh...yeah...thats a different ecm, like a 6070 or something.
Mavric16
