86 Silverado I NEED HEAT
86chev01
Maine
Tyler
I live in Maine and just ended up with an 86 Silverado it's super clean and rust free. Down side is there isn't any heat. So every morning looking out my windshield, is like looking through a sliding glass shower door. What happened was the guy before me ripped out the ac unit and now my firewall has a big square that needs to be covered. I don't know how to go about it because the ac pump isn't there I don't care for ac but it sounds like it might be easier to just put ac back in it than rig something up so the heater works. What do I need where do I start.
Sent from my SM-S820L using Tapatalk
If you just want functional, fab up a sheetmetal duct so the blower motor can actually move air to the heater core.
Georgeb
Wisconsin
George
K10 Burb Z71
This would most likely be the quickest solution.
If you don't want AC you can install a non ac heater but you will need a plate to block off some holes and will need to drill some holes. Just take everything including the controls from the donor truck and if possible a section of the firewall to use as your plate or a template.
I'd have to look it up again, but there is actually a company that sells an AC delete cover. Just bolts on without any firewall surgery and resembles a factory heater box.
Half Assed
SARASOTA
D
R20 3+3, V20 Suburban
'bout tree fiddy
A/c delete cover:
http://www.acdelete.com/pages/73-90_Truck.htm
you could probably booty fab one up with sheetmetal, rivets, and rtv for alot cheaper though.
or get a new a/c air box from the junkyard and just plug up the two holes where the evaporator lines go though
Georgeb
Wisconsin
George
K10 Burb Z71
I have considered one of these myself.
86chev01
Maine
Tyler
Thank you all for the tips.
imyourhuckberry
