85 SWB lowering
Duner13
Mulvane KS
eric
just looking for some quick advice on lowering my 85 SWB. Looking for a "hot rod" truck stance but not to low. Pretty close to the pic. Been looking at Belltech and DJM but do not know what length of drop to get. Any advice will be greatly appreciated
smoothandlow84
I'd rather be draggin' frame
Steve
1500 r10 pavement scraper
3 front 5 rear....using spindles and rear hangers, plus remove your overload springs from the leaf packs. You could "cheat" and cut a coil front the front oem coils (but if you want to do it right, opt for,the drop spindle ). Either way you will also need to get he front aligned afterwards.
Duner13
Mulvane KS
eric
Will that still give me a little bit of a rake, front end a little lower than the rear, or will that make it level? Also preference between Bell Tech or DJM, or a different brand? Shock recommended or not needed? I really appreciate the help through this, just trying to do it right the first time.
spanky55amg
I'll give u $5, a hardy handshake, & 5 fish sticks
Dallas, TX
Spanky
C10 Short Fleet
V8
From the factory, if I am not mistaken, there is a 2 inch rake. I plan on doing 3/5 and it being even. So you would be looking at 3/4. Crown has a decently priced 3 inch drop spindle for the front and then piece a 4 inch drop on the back, which should just be a flip/hanger kit.
bluex
Spartanburg SC
C15
That doesn't look too be lowered very much to me. Go with a 2.5" spindle an a shackle hanger setup for 4" in the rear. You can still run stock replacement shocks on that drop to.
radio2000
South Carolina
83 and 88
83 C10 and 88 R10 Burb
As said above
2.5" Mcgaughy's drop spindles
Hanger kit for rear.
Should still have take
smoothandlow84
Steve
Dont use Crown parts , you definately get what you pay for. McGaughy's spindles while a little bit more, don't have issues with being cast wrong or holes not lining up. I started off with a 2-1/4 front and a 4 inch back drop...then progressed to being bagged front and rear. Start off small and you can make adjustments to you liking. Shackles in the back will not make a huge difference and you can always soften or drop a bit lower by removing leafs. With a spindle drop of 2.5-3 you can maintain stock shocks. With shackles in the back, yoh can also use stock shocks.
smoothandlow84
Steve
Rear shackles of 3 inches plus will also require bed rails to be notched in most csses as well for travel clearance.
spanky55amg
Dallas, TX
Spanky
C10 Short Fleet
V8
I thought that it was lower than 4. I read somewhere, sometime someone was running 4 without notchings
There was a post not too far back where people were say Crown was ok to run... nothing like DJM.
bluex
Spartanburg SC
C15
Its never enough is it. I went 2.5/4 to a 5/7 to bagged and now I am scheming how to get those last 2" to get the crossmember on the ground.
smoothandlow84
Steve
.............bodydrop that sumbitch....lol
I too have about 1-1/2 inches to go til frame becomes one with the pavement.
Brent Butler
Commerce, GA
Brent
GMC
I used a Belltech 4/6 and didn't have to C-notch the rear. I did have to remove the factory bump stops. Here is pic, no weight on the
front yet but give you an idea on the rear with 20's.
smoothandlow84
Steve
Your ride will improve with a mini notch...all it takes is one good rolling dip, and you'll see. Back before I bagged my squarebody (1984). I installed a mini notch and it made for more clearance and a better ride. Some peeps don't bother to add one, but if you ever use the bed of your truck it comes in handy.
GRat
