85 K20 Scottsdale intermittent headlights
Tomahawk4x4
Iowa
Tom
Hey all. Bought this pickup from an old farmer that used it to plow snow before letting it sit for 10 years. I've been fighting this for about a year now. When I got the pickup, the headlights didn't work at all. After working on a few other things, i decided to play with the headlight switch and the low beams finally came on but only the passenger side came on. Played with it some more and the drivers side came on with the passenger side but the high beams would not come on. Wiggled all the wires and it didn't help. Replaced the headlight switch and dimmer switch (on the column) and it didn't help. Few months later, high beams decided to start working. Once in a while the highs will shut off by themselves and it takes forever for them to come back and lows also work correctly when they want. I want all the advice I can get.
Jgonick
West Texas
Joel
Start by checking the headlight grounds are making good contact.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
Tomahawk4x4
Iowa
Tom
Yes. Check the firewall ground on the rear passenger side of the engine too.
Those are good on the rad for sure I just repainted the top. Contacts are clean. Will check the firewall ground tomorrow I'm out of sunlight. Anything else to check for?
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
You'll have to start checking continuity to ground at the headlight sockets as well as power. Just a simple cheap voltmeter will work.
nvrenuf
Mobile, Al.
I struggled with no headlights on my Blazer for months that turned out to be a loose male spade connector in the engine compartment side of the wiring harness bulkhead plug.
I fought this on the weekends for months and was at my wits end. I Hail Mary purchased a Power Probe and had it diagnosed in under an hour. The ability to push power through a circuit anywhere made quick work of figuring out where the dead spot was.
Tomahawk4x4
Iowa
Tom
Interesting...
ali_c20
Austria
Alexander
C20, K5
Welcome from Austria. Post some pics of your truck.
Methodically check all parts of the circuit one after the other so that you don't miss anything.
legopnuematic
Licensed Junk Dealer
MO
Spencer
Welcome from Missouri.
Marine Corps Moderator
:welcome:
wshoneybadger
