85 c10 square body no spark HELP!!!!
New_Guy
colorado
Shane
I just got the truck for my dad and we have absolutely 100% no spark I replaced the battery, coil, distributor cap, rotor, icm, plugs, and plug wires. Please help I'm at my whits end! Thank you in advance!!
Sent from my HTC 10 using Tapatalk
75Monza
Colville, Washington
K30, K20, K20
Silly question, for starters, when you crank the motor, does the distributor shaft turn?
74 Shortbed
Do you have a full 12 volts to the distributor?.
New_Guy
colorado
Shane
Yes it does
75Monza
K30, K20, K20
Another thing, have you checked the pick-up coil to see if it's good? It's the gizmo under the rotor that the ignition module plugs into, should be two wires with a plug end, can check it with an ohm meter. Easiest to check with distributor removed and rotate it by hand checking across the wires, then to the distributor body to make sure bearing didn't go bad and short it out.
Pickup coil test below. I agree, best to test it with the distributor removed, but you can get an idea of whether it's working or not with it in there. I've tested it with it in there before.
It's important that you don't have too much of a voltage drop when cranking. Also, don't discount your new ICM failing on you. The house brand ones are trash, and I even did an AC Delco replacement that lasted for three seconds and burnt out. I had to re-replace it, and then it worked after that. What brands of parts are you using? I like the BWD ignition coil because it's easier to get your hands on and still works well and then everything else AC Delco.
New_Guy
colorado
Shane
I did the test on that before I replaced the icm and that tested good but I didn't do it out of the truck.
New_Guy
colorado
Shane
Ok, did you check how much voltage you have while cranking?.
If I remember correctly I did, but I'll double check to be sure.
New_Guy
colorado
Shane
I'll look into it, I'm almost tempted to replace the whole distributor with a msd brand one.
74 Shortbed
Yeah, wouldn't hurt, if you have too much of a drop you won't have enough for the coil.
Todd Lemon
