Casey Rayls
- May 20, 2025
- Rising Sun, IN
- Casey
- K10
1982 K-10 (4x4). Replaced all gauges in the instrument cluster. Old/Original gas gauge did work, but needle was broke off. Got a new gas gauge and printed circuit board from LMC Truck. Now gas gauge pegs at 3 O'clock.
Everyone blah blahs about poor ground or pink wire this and pink wire that. Well, there are NO wires coming off the back of the gauge.
It has 3 studs which plug into 3 little metal clips, which snap into the printed circuit board.
There is only a harness that plugs into the plastic dash cluster itself (via and thru the printed/wire ribbon circuit board).
The other gauges (oil pressure and voltmeter) work (sans the speedo.. which is also NEW and reads 15 mph too slow).
The point is, the old gauge worked. Nothing was changed except the new circuit board was installed. Now the new gas gauge pegs at 3 as I said.
I say the circuit board is just a dud from LMC as only one of the mini lamps will light up while in the circ. board (checked them all via leads from a battery and all light individually, when out of the panel/cir. board).
The old printed circuit board had cuts in it and was just taped together, but it did work. This all new gauge cluster and cir. board is basically junk and hasn't been worth my headache.
Suggestions ?
I can't see tracing a ground when there's nothing the gas gauge grounds directly to as I think it is supposed to ground via the circuit board.
Suggestions ?
