81+ black interior panels
bluex
Spartanburg SC
C15
Almost a full black interior panel setup. Missing the a pillar pieces. One of the b pillar is broken around the screw holes but you can't see it with the seat in position. $50+ shipping obo/trade
bluex
Spartanburg SC
C15
Bump, any offers?
bluex
Spartanburg SC
C15
I'll make you a deal on all of it an the vent window frames
Marine Corps Moderator
Is it me those look blue not black?
nvrenuf
Mobile, Al.
I see blue, too.
chengny
Is that cargo light wiring harness complete/intact?
If it is, I would be interested.
bluex
Spartanburg SC
C15
I got as much of it as I could so its fairly complete. The cargo light itself was already gone though.
John81287
Mchenry,IL
V20
Well if he doesn't take it I will gladly add it to my list of parts
Sent from somewhere in Northern Illinois!
chengny
I see the cargo light switch and assume the connector is still attached in the back.
I am not too concerned about the connectors at the wire ends for the dome/cargo lamps. If they are still there, good - if not, I'll deal with it.
There should be two other connectors that are necessary:
Actually one of them should have a plug and a socket - that is the one where the dome light leads split off from the cargo light leads.
The only other one is the common connection. It is normally located behind the RH rear speaker. Connects the dome/cargo circuits to the wires that come from the front of the cab. Those feed wires run along the sill plate - under the floor mat/carpet. That will only be a half of a connector - (IDK if it's male or female).
Yeah I figured that. I have one that's in decent shape and am considering buying an NOS housing - I have a real nice lens and the mounting hardware. The cargo lamp housing is about $85 at Nalley's. We'll see.
I do want it.
Paul, are you set up to take payment by PayPal? Also, could you strip the harness off the panels, lay it out and post an image of the connectors as described above.
bluex
Spartanburg SC
C15
chengny I do take paypal. Here are some better pictures of the harness.
The connectors are present for the switch and so is the bulb connector for the dome light. The end had been cut for the cargo light already. I pulled the wire out as much as I could but didn't see this other connector by the speaker so I cut it there as far up as I could. There is enough there for it to run all the way up to the dash though as I reached up underneath the dash to cut it. I was in a hurry an should have spent a few more minutes looking for the connector. Here are the pictures.
Hope those help...
bluex
Spartanburg SC
C15
Kick Panels sold. Make offer on the rest. Headliner tirm, B pillar trim and the small pieces that connect the A pillar trim to the kick panels left.....
chengny
Looks good - I can work with it. Want to close? PM sent with my phone number @ 1610
crpntr78
Missouri
I see that this is an old thread but since it's still up I'm wondering if you happen to have the black seats belts still? Thanks
Original
