8-Lug 2wd Spindle Lift '76 C20
RADustin
New Orleans
Dustin
C20 Crewcab
Hi,
I'm looking to see if anyone know more about the 88-98 4" spindle lift that people are doing on the 2wd 73-87 3/4tons.
As I understand it- the 88-98 balljoints fit in the 3/4 ton arms, and the lift spindle tie rod arm can be reamed out reverse of the 88-98 taper to accept the 73-87 tie rod from the top. As in the 88-98 comes in from the bottom and the 73-87 comes in from the top. Then use 88-98 brakes and hub/rotors.
Most swaps I find, people are using 1500 5 lug hub/rotors or 6 lug 2500 hub/rotors.
I also see where rough country only lists the lift spindles for 6-lug 2500, not 8 lug.
What I'm trying to determine is how do I lift the front of an 8-lug truck, and keep it 8-lug? Wheel adapters are not in the question.
I will eventually go SAS, so I'm hoping there is an easy solution for an easy stepping stone so that I can order my long term wheels and tires.
TIA
Craig 85
Nashville, TN
Craig
K30 SRW
454/TH-400/NP205
This isn't 4" lift, but I used it on an '80 SRW crew cab with a 454. It raised it 2-3". If I recall, I only had to trim the fenders a little to fit 33x12.5x16.5 on 9.75" wide wheels.
https://www.airliftcompany.com/shop/81560/
Dons79C10
