'79 C10 choke light
79Scott
N37°20’26” - W77°40’34
Scott
C10-Silverado
305ci
Hey guys,
I just replaced the carb on my 4.1L (2bbl quadrajet) C10 and hooked the electric choke up. The original owner from whom I purchased the truck from had disconnected it I assumed because the choke housing on the carb was gone. With the choke now hooked up the choke light on the dash stays on all the time. Any ideas?
I did connect up the light blue wire from the wire harness to the choke....
We'll have to get @chengny in here to help with this one. Don't be surprised, and yes it's true, it could have something to do with your oil pressure.
That seems odd...........
That's why I said believe it or not. And it actually does make sense. If you've got very cold oil and not making good oil pressure, you wouldn't want your engine running at high idle. It would take me a few minutes to dig up the correct answer as to why but if my memory serves.... yes it does have something to do with your oil pressure.
Are you saying it was a blown fuse that caused the light to stay on?
alwaysbroken
