'77 Poncho Fuegobird
I'd have you bring it my house too, but I think i'll wait till you shoot some paint on it first. Hurry up wouldja !!!
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Got my side cap bolts for the main caps in and torqued everything down.
Well I hope its all torqued down.
First time doing angle torquing
Also have a set of flat top pistons ordered.
This thing is never going to get built :jester:
Swims350
Logan WV
none
not me I'd rather do the paint and body work myself, build the motor and install it all that fun stuff.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
:jester:
Really, its not so bad. You have 2 choices. Replace the floorpans or have powered and stopping via Flintstone !!! Could be good on the mpg, but not so sure the good mpg would outweigh all the shoes you'll be buying.
I've seen much worse. You have lots to work with there.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
I thought it looked better than I thought it would
Swims350
Logan WV
none
good thing it aint a t-top with them bad floors. They got replacement pans so you'll b alright.
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
God I need a MIG welder
Fix that thang the way I do rust repair. :evillol:
Manbearpig
Midland, Tx
Tyler
1500HD Quadrasteer
Put a board over it?
Swims350
Logan WV
none
nah tin and rivets, some duct tape, fiberglass, spray foam, resin, fiberglass mat or curtains, sheet metal screws, deck screws, or just drywall screws it'll work.
Oh don't forget a couple of road signs they works great LOL.
f1shman
http://www.tractorsupply.com/mig-welders/hobart-handler-reg-140-mig-welder-3812040
Don't bother with the Hobart 125 unit, get the 140. The 140 will be able to run a bead on steel up to 1/4" which is more than enough for just about anything you want to do on your Pontiac. Get a welding mask, gloves (at least), slag hammer and a bottle of argon with that welder and you'll be good to go. Oh, and go to the pull-a-part and snag a twisted fender or something that you can practice your welding on before you start in on your car. :grd:
Shak379
