77 big10 roller 5.3 LS swap
Gonzalo_3
Gonzalo
5.3 LS
This is my first LS swap ever on a 77 big 10 Silverado. I found this truck in a field and its just a roller. I feel confident about the swap, however I just wanted to run some stuff by this forum to see if y'all have anything to say about my plan. I have a donor truck (2004 Yukon) and I plan on using the engine and engine wiring harness out of the donor. I will need a new body harness to wire everything back up. Another concern of mine would be mating a Th350 and making sure I have the correct engine mounts, transmission crossmember for a solid power train. My main concerns are with the mating of the LS and TH as well as the chassis wiring. Like I said this is my first swap and I'm looking for some help with my "pre swap thoughts". Thanks :)
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
Does the donor truck not also have a trans?
Edelbrock
Earth
Grumba
K5 Blazer
Ya, like he said - I would try to keep the LS engine with the "LS" trans, for several reasons.
Gonzalo_3
Gonzalo
5.3 LS
Yes I have a 4L60 that works, however its slips and idk if I want to fight a uphill battle with this trans or swap it just to get another transmission. If i have to use it then oh well, but my thought was just to use a TH350.
Half the reason to do the swap is the modern, fuel injected engine. The other half is to gain an overdrive. Find another 4L60 or get that one rebuilt, would suck to go through all that work and still be singing on the interstate.
Seriously, it's no extra work to do the 4L60. Just 1 more leg on the harness with 1 more plug. Much harder to keep the old trans. I used Tejas Steelworks engine mounts, trans mount and fan shroud when I did mine. Very nice stuff. I'm tellin ya man, nothing better than to be able to comfortably run 80+ on the interstate and the truck is just loafing along. I can run out a quick list of stuff I used if that'll help ya. I've got 56k miles on it now and it's been awesome
Gonzalo_3
Gonzalo
5.3 LS
Thanks man and I would like that list plz
Going to a 4l60/700r4 depending on what tires you are running and what current rear gear you have,you may end up having to change rear gears also. Do you know your rear gears and what tires you are going to run?
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
Prepare a plan for the fuel system which can be a costly addition to the EFI swap.
You’ll need a tank (or tanks) for an ‘87 with the fuel pump baffling. ‘87 fuel sending units, EFI rated pumps, fuel lines, add a return line, a tank switch rated for EFI pressure, fuel filter Etc.
You could do a fuel cell instead but that comes with its own list of costs…
There may be other options for the fuel system too but I don’t know what they are
The truck side part of the swap harness is simple and nearly the same as what’s already there, here are some basics.
Purple wire to starter
Brown (IIRC) alternator exciter wire
Two red wires from battery (positive lug on starter and back of alternator each with fusible links)
Green (IIRC) A/C pump
Green temp sender
Tan oil pressure sender
Pink ignition coil (if not part of the PCM harness)
For the PCM you’ll need to feed it:
One constant hot wire (batt)
One wire Hot During run and crank but open when the key is off.
(Most of the positive circuits in the truck will cut off during engine start which will not work)
Ground
Everything else should be on your donor harness
There's been several changes since I initially bought the truck but here's the basic breakdown of when I first built it (put 27.5k miles on this setup):
- Aluminum LH6 5.3 and 4L65E out of an Envoy Denali with ~106k miles
- Fresh filter/fluid in the trans, nothing more
- All gaskets/seals/head gaskets on the engine
- Tejas Steelworks engine mounts, transmission mount and fan shroud for dual 13" fans
- Spal 13" fans, there's 3 different CFM ratings, I grabbed the middle ones. Off Amazon. My buddy had the top CFM rating and you couldn't hear anything over his fans outside the truck lol
- Speed engineering 1 3/4" longtube headers and spark plug wires
- PSI Conversions harness (they have since pissed me off with their ****** customer service and I will buy BP Automotive harnesses in the future)
- GM Muscle Car swap oil pan kit
- BTR Stage 4 V2 truck cam (224/230 .553/.553 109lsa)
- LS7 lifters and chromoly 7.4" pushrods
- Circle D 2800-3000 stall converter (should've gone a touch more, would suggest a 3200-3400 with that or similar cam)
- Yukon Duragrip 30-spline posi unit, Richmond 3.90 gearset, bearings/races/seals, 30-spline axles from Quick Performance
- Squarebody Syndicate Series Dakota Digital gauges and a Dakota BIM module to pull most info from the computer
- 2.5" pipe with an X-pipe, Borla ProXS mufflers in the traditional spot then more 2.5" pipe out the back exiting behind the rear tires
- Spectre CU730 big block radiator, stock replacement
- Big block upper rad mount and cushions
- L99 Camaro water pump, '06 Corvette upper hose
- '87 fuel injection tank and sending unit. Walboro 255 pump.
- Braided AN6 line kit off Amazon for the fuel lines
86 C10 Shortbed
Ohio
Mark
5.3L
I put new crate 5.3L in my 86 C10 Shortbed after I had the junkyard 5.3L smoke 1” rod bearing after I installed a new BTR cam and springs, happened cruising 35mph at less than 200 miles. Sold the cam to a friend and he installed it in his LS and fried a rod bearing. Cursed Cam? We’ll never know. The new crate is 460hp at the crank and 350hp at the wheels. Circle D 3400rpm torque converter and posi with 373 gear. Cruises great on the highway and smokes the tires with ease.
Tyler22474
