77 big10 roller 5.3 LS swap
Gonzalo_3
Gonzalo
5.3 LS
This is my first LS swap ever on a 77 big 10 Silverado. I found this truck in a field and its just a roller. I feel confident about the swap, however I just wanted to run some stuff by this forum to see if y'all have anything to say about my plan. I have a donor truck (2004 Yukon) and I plan on using the engine and engine wiring harness out of the donor. I will need a new body harness to wire everything back up. Another concern of mine would be mating a Th350 and making sure I have the correct engine mounts, transmission crossmember for a solid power train. My main concerns are with the mating of the LS and TH as well as the chassis wiring. Like I said this is my first swap and I'm looking for some help with my "pre swap thoughts". Thanks :)
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
Does the donor truck not also have a trans?
Edelbrock
Earth
Grumba
K5 Blazer
Ya, like he said - I would try to keep the LS engine with the "LS" trans, for several reasons.
Gonzalo_3
Gonzalo
5.3 LS
Yes I have a 4L60 that works, however its slips and idk if I want to fight a uphill battle with this trans or swap it just to get another transmission. If i have to use it then oh well, but my thought was just to use a TH350.
Half the reason to do the swap is the modern, fuel injected engine. The other half is to gain an overdrive. Find another 4L60 or get that one rebuilt, would suck to go through all that work and still be singing on the interstate.
Seriously, it's no extra work to do the 4L60. Just 1 more leg on the harness with 1 more plug. Much harder to keep the old trans. I used Tejas Steelworks engine mounts, trans mount and fan shroud when I did mine. Very nice stuff. I'm tellin ya man, nothing better than to be able to comfortably run 80+ on the interstate and the truck is just loafing along. I can run out a quick list of stuff I used if that'll help ya. I've got 56k miles on it now and it's been awesome
Gonzalo_3
Gonzalo
5.3 LS
Thanks man and I would like that list plz
EOD82K10
