750
yevgenievich
Viktor
sad
very sad
less sad
Picked up a beat up shadow 750 the other day. Does not run, out of state, no title, no keys. Fun
animal
Lee
c10 silverado
350ish
Interesting new project :waytogo:
73c20jim
Tombstone, AZ
Is that the drug sniffing dog????
yevgenievich
Viktor
sad
very sad
less sad
The story goes that it actually ran in Mexico for a while, and one of the other dogs fipped out barking at it for a bit...
yevgenievich
Viktor
sad
very sad
less sad
To me it looks to be ridden hard and not maintained. Oil was new and have not seen a single start...
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
*** bikes don't run right if you try to maintain them.
yevgenievich
Viktor
sad
very sad
less sad
Got the oil fill plug threaded correctly, found cut up battery and fixed ignition switch followed by the gasoline cap repair.
Jrgunn5150
Questionable methods
Ionia Mi
J.R.
6.slow
Sweet, i just got a crappier *** bike lol. I guess I'll start a thread too.
yevgenievich
Viktor
sad
very sad
less sad
Starter was shorted internally. Got it cleaned and fixed the short. Now it cranks but only with a second screw driver upgrade. Starter relay is bad. Next step will be to check the spark and then maybe fire. It also needs a new battery. 19k miles on the odometer.
K201979
Winona, missouri
Hippie
350ci
Sounds like itll run good once u get it all lined out.
yevgenievich
Viktor
sad
very sad
less sad
I have avoided putting any money in it so far. The goal was to at least see if motor is ok before actually spending money on it. Now that it seem to have potential, need to first get better idea if i can get papers for it and if so; to order a carb kit, fuel shutoff valve, battery and maybe a starter relay. Fuel pump is also bad, but I just bypassed it and made sure there was more than min fuel in the fuel tank.
K201979
Winona, missouri
Hippie
350ci
Find someone who can put a mechanics lien on it for u
yevgenievich
Viktor
sad
very sad
less sad
Only issue is that it is out of state. It has to pass inspection to get the paperwork going. Person I got it from thought it was from Mexico, but although it spent time there does not look like it was for Mexico market due to federal stickers and such.
Basically I need to get the cross state vin search done to make sure it does not have issues somewhere
87R10_Cruising
