75 Chevy Fleetside
Did the pics show up now? My media page was set to private for some reason.
Nice, I can see the pics. Looks like you got a standard 10 bolt 3/4 ton front axle. I can't tell what transfer from the pics. If you can get a shot of the trans/transfer I could tell what model. Also should be able to tell from a closeup of the transfer case shifter knob. It looks similar to my NP205 shifter but could be a 203 depending on what shift positions you have. If you have hi-lock and lo-lock it is a 203. If you only have 2Hi, 4Hi, and 4Lo its probably a 205
what is your t case
that knob looks a little like a special or not oem kind unless i just havent seen one. my np203 and np205 knobs are tapered toward the base where they screw on and the top is circular
1973c10
Don
Welcome :boti:
Squinko
Pinetop, AZ
Benny
Here is some pics of the transfer case and shifter inside. It has the code C-99404 with AA under the code. I take possession of the truck in about a week. I can't wait to start tearing into it. There are so many fluid leaks !!
View media item 9444View media item 9446View media item 9447View media item 9443View media item 9442View media item 9445
That's a 70-77 GM NP205 with a slip yoke eliminator... it's about the most bulletproof and desirable off-road setup you could have.
84lsc10
