700R4
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I have my trans removed and was wondering if the input shaft should be able to turn by hand when it's put in neutral?
1985c20
Torrington, CT
Chuck
Probably not. With an automatic the input shaft is spinning the pump, not like a manual where in neutral its not spinning anything. You should be able to spin it with the torque convertor installed on it though. Just cant get enough grip/leverage on it by hand.
Depends on your hands I guess. Normally you should be able to slowly turn the input, but it may be a little uncomfortable.
mmerlinn
Here, there, and everywhere
mmerlinn
1977, 1993, & 1993
Ranger, Aerostar, & Aerostar
460, 181, & 181
If you are talking about the SMALL shaft, yes, though it may turn hard. If you are talking about the LARGE shaft, NEVER.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Thanks for the info, was just wondering. I'll be taking it to have it rebuilt.
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
Another question, the wire connector on the drivers side has one wire (green) going to it.The green wire hooks to a wire going to the injector pump, now is this some kind of speed senor type wire? I'm in the process of cutting the diesel wires out and I'm almost finished.
twzorek
