700r4 to th350
jth678
georgia
john
v10 custom deluxe
i am buying the adapter kit to put a turbo 350 in my truck but what i am wondering about is will the 350 work in place of the 700r4 because of the electrical sensors? like the speed sensor etc. any help is appreciated greatly!
gpmorgan
Tupelo Ms.
greg
Not sure why you want to get rid of the 700 r4. But yes, there will probably be an issue with the speed ometer. There may be some aftermarket parts to correct the problem, not sure.
Swims350
Logan WV
none
because 700r4's suck.
now how new the the said vehicle? I ask because I wonder if in fact it does have speed sensor or if it's just something else.
Swims350
Logan WV
none
ha not me, never had a good one seen no use in having one, around here too many hills to climb to make any real use of od, unless you have tall gears then maybe, but they just all seem way too weak. All we had were just sluggish and soggy. The tv cables never adjusted as they should either.
lower first gear ratio is the only good thing I can think of on them.
if I ever had a nicely modified one I might change my mind.
gpmorgan
Tupelo Ms.
greg
I've done a lot of pulling with mine since it was new. Race cars, small tractor, gravel, ect. Never a minutes trouble. I had it rebuilt about 7 yrs ago. That was because I added about twice as much hp to it. Been performing flawless. Turns them over a couple times between 1st and 2nd and barks sometimes when it shifts to 3rd if you really have your foot in it. So I have no complaints.
Swims350
Logan WV
none
oh yea you got a good one then beefed up and shift kit etc.
if I had one of those I'd enjoy it too, honestly I just preffer a stick but my old man getting old and my wife can't drive stick lol.
gpmorgan
Tupelo Ms.
greg
I don't know how much truth is to it, but my tranny man said that the 92 was one of the best years for the 700r4. He was probably just pulling my chain.
gpmorgan
Tupelo Ms.
greg
Looks like he's got a 87 v10??
Swims350
Logan WV
none
yea I missed that lol, but yes I heard the newer 700's were better too, hrpd would know for sure.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
If you have an 87', the VSS is in the speedometer cluster, driven by the cable, so swapping in a TH350 will be no problem. A 9" tailshaft TH350 will swap directly in place of a 700R4, same driveshaft and everything. Just leave the TCC connector unplugged, it will be fine. You will need a different dipstick, TH350 and 700R4 have the dipstick in a different location on the trans. You will have to move your transmission crossmember, but can use the same mount. The holes should already be drilled in the frame. I think that's really it.
I speak from experience, just did this swap on my 84', which has a full 87' TBI drivetrain in it (fuel injected and all).
jth678
georgia
john
v10 custom deluxe
ok thanks guys i appreciate the help! the reason im switching is because i traded a four wheeler for the truck and the guy i traded to gave me a freshly rebuilt th350 to go in place of the 700r4 because its burned up. i dont think he knew what tranny was in it to begin with and just bought one that someone told him to get. which i would much rather have the 350 because they are cheaper to rebuild and im just building a weekend mud truck. anyways i just decided to buy the advanced adapters kit so i could use the one he gave me and not have anything rebuilt. so far ive got 200$ in the kit and 75 in the guy thats putting the shaft in for me plus 60 for a new torque converter so i feel like im coming out cheaper than having the 700r4 rebuilt. and yes its an 87 v10
gpmorgan
Tupelo Ms.
greg
Under those circumstances, I don't blame you. Your right, it would be way more expensive to have the 700r4 rebuilt.
jth678
georgia
john
v10 custom deluxe
ok so if the speedo cable is broke then that will make my vss act all crazy right? because when its idling in neutral its idled up really high. does this sound right if the vss isnt working properly?
Swims350
Logan WV
none
I don't think vss would control your idle I'd think something else is making your idle high, vac. leaks or sensor etc. so being 87 it's tbi right?
