700R4/NP241 to 4L80E/NP241
cobra20
Portland, Oregon
Hans
V1500 Suburban, K5 Blazer
5.7L
So guys what would I need to grab to convert my 1991 suburban from the 700r4 to the 4l80e from the junkyard. I believe I would need just the transmission, transfercase, wiring harness, and the computer. Is there anything else that I'm not thinking of?
MadOgre
NA
NA
NA
NA
NA
You can simply replce the input gear with a 32 spline shaft for about $150 or get the rebuild kit for $120 and another $100 for the 32 spline input gear. That will give you new bearings and seals and shift fork pads and then you can fix anything else you see wrong while your at it.
Problem is if you pay more then $100 for a used one and then you end up having to go through that one anyways it doesn't make sense financially.
cobra20
Portland, Oregon
Hans
5.7L
Well I figured I would just grab the transfer case that is on the 4L80E so I don't have to change anything over
MadOgre
NA
NA
NA
NA
NA
Well that makes life easy. For sure grab the cross member that the 4l80 uses
RetroC10Sport
Green Bastard Parts Unknown
Jay
pontiac aztek
http://row52.com/Vehicle/Index/1GNGV26K6MF150581
This is a 4L80E/241 truck at the North Portland Pick-n-Pull. Maybe all those goodies are still there. :waytogo: Probably the one you're getting it out of, isn't it? haha
I need to get caught up, been way too busy.
cobra20
Portland, Oregon
Hans
5.7L
Yeah I got the driver side power mirror bracket off of it. Got my reel light off of it and got the computer out of it yesterday.
BowTieJockey
Tallahassee fl.
Trey
I'd love to find a 5.7/4l80e square body harness and computer, for the same conversion your doing.
BowTieJockey
Tallahassee fl.
Trey
I could also be interested in your 241 from behind the 700 if your willing sell at reasonable price.
MadOgre
NA
NA
NA
NA
NA
Totally off topic but HotRod Says you know where and who sells brandnew non reman steering boxes for our squares ? Is that true ?
PapaBear8486
