tegra
- Jan 10, 2016
- Texas
- William
- c10
So someone has put a remote mount filter on it. Nothing wrong with that IMHO, and the horizontal position should make it easier to catch the oil in a pan when you remove it.
yes the idea is ok but the way it was laying down was awkward and didnt seem like it was used as intended.
anyways update on the engine i have bad news i had time to day to pull the dipstick and check oil and was in process of changing it. unfortunately it was sort of greyish color and has me worried water is in engine. i have taken pictures of it and will post them asap. i pulled valve covers and it was sort of snot looking crap on the top of covers (wiped clean) i took my air compressor and covered the oil ports and blew all of it off the rockers ect and while i had them off i took some pics of the numbers stamped in heads. so my plan is to flush rest engine with some cheap oil let it get to running temp and drain it then once more and if no water is in it change with some good quality oil. could an engine be sitting too long have a good bit of condensation build up in it? what are yalls thoughts i provided as many pics i could take before it started raining.
