6.5L Turbo Rebuild?
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Hey guys. I found a complete turbo set-up off a 6.5L for fairly cheap. The only problem is the turbo is "no good". Iv seen pictures and its not blown. How hard is it to rebuild a 6.5 turbo? And is this set-up a direct fit?
MrMarty51
Eastern Montana
Martin
Sometimes, it is cheaper to pickup a rebuilt than to do a rebuild on Your own. If You trust someone elses handywork.
I know nothing about if it will fit, or not.
My old boss said that the entire setup should swap over, but it's been years and I could be forgetting any complications he mentioned.
MrMarty51
Eastern Montana
Martin
I wonder if the pistons for the turboed engine would be a bit lower on compression and possibly a heavier duty piston too. ???
Jims86
Patterson,Ca
K10 Suburban Silverado
5.7 TBI
Its usually the seals and barings that go in the center section. You may be able to get a kit. **** happens because people dont let it idle down after jammin down the road. Guys drive up, throw it in park, shut it off.....you can still hear the turbo spinnin.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Yep, then all that heat cooks the oil in the turbo, resulting in "coking", and it kills the bearings.
Jims86
Patterson,Ca
5.7 TBI
Not to mention, crankin at 10k rpm with no oil pressure.
It's my understanding the Turbo set up from a 6.5 is supposed to be a direct bolt on to the 6.2. Not positive though. I've not done it myself.
Stroked
Beloit, Kansas
Jared
It won't fit if you have factory A/C as the passenger side manifold hits. If you feel like hacking up the plastic A/C box under the hood then you can make it fit. I know it's been done several times.
I'm hoping to run across either a Banks kit or an ATS kit that was sold for the early GMT400's that still had the 6.2
MrMarty51
Eastern Montana
Martin
How about changing to an air box from an air conditioned pickup/suburban that, had A/C ???
Make it look unhacked and original, if it would work.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
The previous owner hacked up the A/C for me... You don't realize how nice A/C is until you don't have it lol
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Heres an idea for ya: What if I got 2 6.5 turbo manifolds and flipped one around so itd bolt onto the drivers side? Is that possible? Im sure SOMEONES tried it... Id have to mess with the wastegates to make sure each one is only running 4-5 psi lol
sever
