6.2 tweeks
Chuck
Grande prairie
Chuck
K30 crew cab
Any one done any small tweeks or minor upgrades that mad a diff to the 6.2.
MadOgre
NA
NA
NA
NA
NA
http://www.dieseldepot.com/index
Give these guys a call. You can change the timing and turn up your fuel delivery. But on the stock 6.2s you increase the chance of heads cracking when you do.
marks86
Latham, NY
Mark
12v Cummins
you can bump up the timing the width of a dime, get a turbo kit
Chuck
Grande prairie
Chuck
K30 crew cab
I just check timing It already looks advanced. Is there any way to tell if fuel is already turned up
marks86
Latham, NY
Mark
12v Cummins
does it puff black smoke out when you romp on it, that's one way.
at one point I owned two of the exact same cucv but one was noticeably faster and would give a good puff of black smoke when I hammered down
still slow as **** though
marks86
Latham, NY
Mark
12v Cummins
I mean those also make headers for it, but for that price a turbo kit is really the only options for those motors, and even with that your just keeping up
Chuck
Grande prairie
Chuck
K30 crew cab
My truck does feel like it's got lots of jam. No black smoke. I do have the j code heads and intake and arp studs. Does j code swap make a dif. I do got a line on complete 6.5 for cheap
marks86
Latham, NY
Mark
12v Cummins
j code(emissions free) has like twenty more hp
Chuck
Grande prairie
Chuck
K30 crew cab
I guess it would be worth it then
columnshift
Minnesota
Mark
1500 heavy half (retired)
I had often thought that propane/methanol type injection could be the cheapest route to boosted power on these motors, after having read of literal homebrew setups giving pretty substantial power boosts (30% more torque!) on other engines - biggest problems being EGT's (the numbers were on turbodiesels) or any other weaknesses of the 6.2 design. (main webs that like to develop cracks and send crankshafts south, more power would worsen that obviously)
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
6.2 are funny creatures. One runs sweet, next is a dog. Had one in a buggy that would flat out scream, it took a dump and second one never did run right. Changed over to original pump, played with trimming , ect... Running a non turbo 6.5 in it now, really runs good for a stock engine. I drive a 6.5 turbo in a 96 k3500 and that non turbo runs as good as it does and mine has new turbo, wastgate, and few other mods
Chuck
Grande prairie
Chuck
K30 crew cab
I was looking at na 6.5 is your surplus
marks86
Latham, NY
Mark
12v Cummins
they make marine injectors also
Chuck
Grande prairie
Chuck
K30 crew cab
I've read some where they don't do much. Has any one herd of bank power kit with na.
boneheaddoctor
Northern Virginia
Lester
It was called a Banks Stinger. Included a new larger snorkel to modify the airbox, adapter and hose for a cold air inlet from the right of the radiator through the core support, Y pipe and exhaust system and EGT gauge.
Don't know if they still make it, because I put mine on well over a decade ago. Livened it up, still with I would have done the Turbo kit but was worried about manifold studs breaking off in the head. And that kit was a lot more expensive. Money was short at the time, as well as was spare time. My old exhaust system (duals) had rotted off and needed something quick.
The biggest downside is the intake resonator is removed and it (the intake) makes a horrible droning noise around 50-70 mph.
sallyjeank10
