502 Ac Lines
Darin McG
ALTA
Darin
I just finished installing a 502 crate engine into my 86 c10. I also install the chevy sirpentine belt kit with the ac compressor. So my question is if anyone can tell me what hoses to order (part #) for the ac unit all info will help.
84 M1008
New York
Wayne
M1008 K30
6.2 diesel
Good lord that thing must be a handful. Niice!
78C10BigTen
pennsylvannia
C10 BIG TEN
Id KILL for a 502 in my square!! I just found a 409 on cragslist but i couldnt touch the $5500. price tag...
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
yevgenievich
Place
Name
Year
Model
Size
Places like https://coldhose.com/ can do it if no local solution exists. If brackets are aftermarket, stock big block ac lines unlikely to fit
Darin McG
ALTA
Darin
The serpentine belt kit is a chevy 19366895 for the big block> but i will check out coldhose for sure
1973c10
Don
:welcome:
yevgenievich
Place
Name
Year
Model
Size
It appears to be placing the compressor in a stock 89+sbc location. If that is the case, then hoses for 89-91 suburban with only front ac or 89-91 k5 might be a correct fit. Would need to measure and verify if the AC location is in fact close enough.
Darin McG
ALTA
Darin
thx will check out an 89-91 suburban ac line
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
AC draws too much power... oh wait a minute... 502... no worries you're good to go. You can run two compressors and never notice.
VFL1982
