5.3 LM7 going in my 87
fried_daddy
Elkmont, AL
R1500
5.3 LS
I checked the heads for flatness with a 24" straightedge then marked them with layout fluid to begin truing up the surface. Used a flat piece of marble, with sandpaper held onto it with spray adhesive. WD-40 was the lubricant of choice.
fried_daddy
Elkmont, AL
R1500
5.3 LS
After it was all said and done, I ended up with this!!!
fried_daddy
Elkmont, AL
R1500
5.3 LS
Here's a picture of the other head before I started doing it. I used the same process for it.
fried_daddy
Elkmont, AL
R1500
5.3 LS
Flipped the block over to further tear down for inspection.
fried_daddy
Elkmont, AL
R1500
5.3 LS
I was pretty happy with the way everything looked.
fried_daddy
Elkmont, AL
R1500
5.3 LS
I had to clean and paint something!
fried_daddy
Elkmont, AL
R1500
5.3 LS
I ordered this lift plate off Amazon. Makes lifting and moving the blick around alot easier. It also keeps the valley area covered. Highly recommended.
fried_daddy
Elkmont, AL
R1500
5.3 LS
Pistons that I will be cleaning, re-ringing and putting back in the block. Worn out cam bearings that i'll be replacing.
fried_daddy
Elkmont, AL
R1500
5.3 LS
Took the block outside to pressure wash and degrease everything.
fried_daddy
Elkmont, AL
R1500
5.3 LS
Back in the garage with the lift plate in place.
fried_daddy
Elkmont, AL
R1500
5.3 LS
Cylinders after I hit them with the flex hone. New camshaft bearings in place. New main bearings (standard size) in place.
fried_daddy
Elkmont, AL
R1500
5.3 LS
Fel-Pro gaskets ready to go!
fried_daddy
Elkmont, AL
R1500
5.3 LS
Engine going back together. New timing set also installed. Here is a video of some of the stuff I used.
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
Looking good. Keep up the good work!!!
fried_daddy
Elkmont, AL
R1500
5.3 LS
Putting heads on the block with new TTY bolts.
that_orange_c10
