5.3 intake
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Can a 5.3 intake be used on a 6.0?
Yep, all truck engines used the same intake manifold, generally, from 99-06'. 07'-up are a bit different. There are small differences, like mounting bosses for covers, returnless vs return fuel system, EGR, etc, over the years, but they are generally interchangeable.
putt2014
Turbeville SC
Frank
So are you saying a 99-99-06 intake won't fit a 07 and newer engine? I got an 2002 5.3 for my swap but planning to up grade later to a 6.0 just want to know my options.
And thanks for your help
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
99-06' will fit 07'-up with Cathredral port heads. If the later 6.0 has rectangle ports, you'll need to use the newer intake.
dan86
